R47 running lights - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: R47 running lights (/showthread.php?tid=943) |
R47 running lights - Erich - 09-03-2018 I've got R47 headlamps and would like to hook up the running lights. The issue is that there is only the outer case for the running lights but no internal spring loaded fitting. Can anyone point me in the direction of a supplier for these internal bits? Any help is greatly appreciated. Erich In Seattle RE: R47 running lights - Stuart Joseph - 09-03-2018 Good evening Erich, could you email me at stuart.joseph@btinternet.com as I have modern replacements. Regards from the creative county - Staffordshire Stuart RE: R47 running lights - Erich - 10-03-2018 Thank you, Stuart. I have sent you an email. Best, Erich RE: R47 running lights - Zetomagneto - 10-03-2018 [attachment=2406 Wrote:I Erich pid='7929' dateline='1520619289'] I've got R47 headlamps and would like to hook up the running lights. The issue is that there is only the outer case for the running lights but no internal spring loaded fitting. Can anyone point me in the direction of a supplier for these internal bits? Any help is greatly appreciated. Hello Eric, I had the same problem.I bought some bulb holders, removed the plastic terminal blocks, removed the lugs on the outer diameter, and milled flats across them by the terminals. Hope the photos help.Best Wishes Gene (10-03-2018, 09:47 PM)Zetomagneto Wrote:Here are the bulb holders: https://www.autoelectricsupplies.co.uk/product/449/category/81(09-03-2018, 07:14 PM)I Erich Wrote: I've got R47 headlamps and would like to hook up the running lights. The issue is that there is only the outer case for the running lights but no internal spring loaded fitting. Can anyone point me in the direction of a supplier for these internal bits? Any help is greatly appreciated. RE: R47 running lights - Stuart Joseph - 11-03-2018 Good morning Erich, the bulb holders shown are the ones that I stock. Regards Stuart |
