LED Lights - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: LED Lights (/showthread.php?tid=9175) |
LED Lights - Tony Griffiths - 13-02-2024 Following on from the article in the Grey Mag about LED lights, a slightly fuller edition of the article is now reproduced here that allows the various hyperlinks can be clicked. RE: LED Lights - Colin Morgan - 13-02-2024 I've recently fitted a pair of the pre-focus LED headlight 'bulbs' - much brighter - and use them on dull days in the well-lit 'rush-hour' traffic that lasts all day around here - with the added advantage that the 6v dynamo can keep up. RE: LED Lights - Parazine - 14-02-2024 I had a problem with the cheap Chinese LED lights that I found for the Chummy. They fitted the scuttle headlights and the light output was great but they fell apart when used for a half-hour run on boxing day. I've moved on to these, which also fit and seem to work well. Only problem is that I don't have "Sidelights" any more..... Classic Car LED.jpg (Size: 87.83 KB / Downloads: 237) We'll see about the reliability when I actually use them although I have to admit to driving the car very infrequently at night these days RE: LED Lights - Howard Wright - 14-02-2024 (14-02-2024, 11:38 AM)Parazine Wrote: I had a problem with the cheap Chinese LED lights that I found for the Chummy. They fitted the scuttle headlights and the light output was great but they fell apart when used for a half-hour run on boxing day.Hi Parazine I put 9mm sidelights in the headlight bowl and with a bit of extra wiring I get a dip switch. Check out the 2023A Grey Mag for details. Cheers Howard RE: LED Lights - Dave Mann - 16-02-2024 I Bought & fitted a pair of the projector lights about a month ago and I use them all the time, sidelights are somewhat obsolete when the total lighting load is 4 amps. |
