Starter gear - Printable Version
+--- Thread: Starter gear (/showthread.php?tid=8983)
Starter gear - frequentflyer - 12-11-2023
What is the best way to fix a starter gear that needs an occasional prod with a screwdriver. Its a new engine I have built, nearly all machined at home. Its all gone well and runs nicely on the test bed just the starter gear is beating me. Its the last bit of the puzzle before I fit the engine back in the car.
RE: Starter gear - Dave Mann - 12-11-2023
Is the motor shaft bent?
RE: Starter gear - Graham Barker - 13-11-2023
Does it need the prod to engage the gear or is it to disengage the gear?
RE: Starter gear - frequentflyer - 13-11-2023
Engaging is the problem
RE: Starter gear - Graham Barker - 14-11-2023
I seem to recall reading that the gear should not be lubricated, because grease or oil on the spiral may prevent the gear wheel from spinning out into engagement with the flywheel. Perhaps someone can confirm this?
RE: Starter gear - Dave Mann - 14-11-2023
What sort of starter is it? The bacon slicer starter needs the weight on the pinion for the pinion to engage with the ring gear as I found out
RE: Starter gear - SJT - 14-11-2023
As a young apprentice with Joseph Lucas we were instructed not to lubricant the pinion or shaft of starter motors as the dust from the clutch plate could stick to lubricant and cause pinion to fail to engage .
Stephen.
RE: Starter gear - Reckless Rat - 14-11-2023
If it's the later type starter motor there is a two sided spring clip that the pinion rests in after use. It may be that the spring is holding it too tight and preventing it from climbing up the bendix to engage the flywheel. It's a fairly simple job to remove the starter motor and "adjust" the spring tension. Remember to disconnect the battery before you do anything.
