Torque tube anchor point - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Torque tube anchor point (/showthread.php?tid=8750) |
Torque tube anchor point - Nick Salmon - 20-07-2023 Please forgive me putting this on the main forum as well as the 'wants' (which I know some do not look at). I'm changing the whole of the back axle on my Ruby. Currently has a ball type torque tube anchor point on the chassis crossmember. The replacement axle torque tube anchor is of the later type with a silentbloc bushed/bolt. Has anyone got a later type torque tube anchor crossmember mounting brackets they would part with please? RE: Torque tube anchor point - Howard Wright - 20-07-2023 Hi Nick I think David has these (1A5523). But I may be wrong. I made up a pair from thick angle section for my special. Perhaps not for the purist? Cheers Howard RE: Torque tube anchor point - dickie65 - 20-07-2023 Just swap the mount from the old axle to the new one and keep the original ball mount. RE: Torque tube anchor point - David Cochrane - 20-07-2023 (20-07-2023, 06:17 PM)Howard Wright Wrote: I think David has these (1A5523). But I may be wrong. You are not wrong! I also stock the Silentbloc bush. |
