Warning [2] Undefined property: MyLanguage::$archive_pages - Line: 2 - File: printthread.php(287) : eval()'d code PHP 8.1.30 (Linux)
2ba threaded bush - Printable Version
+--- Thread: 2ba threaded bush (/showthread.php?tid=8688)
Pages: 1 2
2ba threaded bush - leaf200 - 26-06-2023
Hi does anyone know where I can get 2ba threaded bushes like the one below.
I want them to secure my chummy door capping
RE: 2ba threaded bush - Duncan Grimmond - 26-06-2023
You forgot to add a pic...
RE: 2ba threaded bush - andrew34ruby - 26-06-2023
(26-06-2023, 07:52 AM)Duncan Grimmond Wrote: You forgot to add a pic...
He wants invisible fixings Duncan.
RE: 2ba threaded bush - Tony Griffiths - 26-06-2023
Perhaps these? https://www.allfix.co.uk/products/threaded-inserts/toolrcl30528
RE: 2ba threaded bush - David Stepney - 26-06-2023
Or Rivnuts?
RE: 2ba threaded bush - leaf200 - 26-06-2023
I am struggling to upload the photo I want the brass split inserts that will expand in the wood
RE: 2ba threaded bush - bob46320 - 26-06-2023
I don't know what the proper way is to load photos, but I write the text and then PREVIEW POST. Roll down to the bottom of the screen
ATTACHMENTS.  Add your photo there.  PREVIEW POST again to see where the photo has "lodged" itself. Huh
Bob
RE: 2ba threaded bush - Peter Hamstead - 26-06-2023
I think you will have trouble finding 2BA wood inserts so would suggest using M5 screws which are slightly larger in diameter because then you have a multitude of options. How about these: https://www.theinsertcompany.com/brass_hex_drive_insert_for_wood_unheaded.php
RE: 2ba threaded bush - Ivor Hawkins - 26-06-2023
I thought that the capping used screws that went through the capping and skin straight into the wood, or have I lost my marbles?
By "capping" do you mean the ali section that runs along the doors and rear section - or the two overlapping castings on each door?
