6v versus 12v Condenser - Printable Version
+--- Thread: 6v versus 12v Condenser (/showthread.php?tid=8606)
6v versus 12v Condenser - DaveT - 19-05-2023
Quick question.
I'm running a Bosch 009 distributor, are 6v and 12v condensers the same?
The spares I've bought don't have any identification, so if it is a 12v is it OK to use?
I would think that a 6v would not working on a 12v system, but what about a 12v on a 6v system.
I have a multimeter so could I test it and if so what would I set the meter too.
RE: 6v versus 12v Condenser - John Cornforth - 19-05-2023
Hi
Both the same.
The condenser sees a peak voltage of 300 to 400 volts on an A7 and condensers sold for this purpose will reliably withstand that.
Multimeter test won't reveal much.
RE: 6v versus 12v Condenser - Bill Dixon - 19-05-2023
Hi Dave T, If it's any help I always test mine with a 500volt megger. If you know an electrician they may be of help.
