Clutch lever half collar - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Clutch lever half collar (/showthread.php?tid=8505) |
Clutch lever half collar - Luke.Seddon - 08-04-2023 Hi everyone, I have taken my clutch apart as it was not operating correctly. One of the mousetrap springs was snapped and a clutch lever half collar was missing. I have found replacement springs on the austin seven workshop website but I can’t find the half collars. Does anyone know were I can buy the half collars from? Many thanks in advance. RE: Clutch lever half collar - Ruairidh Dunford - 08-04-2023 Do you mean collets? As fitted to the very late clutches? I’ve not seen any new ones for some time, but they may be available. Tony Betts may be able to supply to a second hand one… RE: Clutch lever half collar - Luke.Seddon - 08-04-2023 Just to clarify, i have attached a drawing found on the cornwall austin seven club page. RE: Clutch lever half collar - Ruairidh Dunford - 08-04-2023 That’s the type I am referring to, above. RE: Clutch lever half collar - Luke.Seddon - 08-04-2023 Ok great thanks, i’ll reach out to Tony Betts. RE: Clutch lever half collar - Ruairidh Dunford - 08-04-2023 Half Collar is almost certainly correct. My terminology is often incorrect, because I am not a trained engineer, much to delight of those who are. Good luck finding one and come back to me if you cannot, I may be able to help if Tony cannot. RE: Clutch lever half collar - Luke.Seddon - 16-04-2023 Hi, i’ve been unable to get hold of one. If you do have one, i would gladly take it off your hands. Please let me know if you locate one. Obviously i’ll pay. My number is 07402929888 if it is easier to message me direct. RE: Clutch lever half collar - Parazine - 17-04-2023 Luke, If you are in Bristol, are you a member if the Bristol Austin Seven Club? If you are, our spares shed will be able to supply the part that you need. If not, you really ought to be! RE: Clutch lever half collar - Luke.Seddon - 17-04-2023 I am a member of the BA7C, but I was unable to make it to the spares shed this weekend. Thankfully a nice chap has seen this post and is sending me some in the post. Many thanks all. |
