Item sought for the Archive - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Item sought for the Archive (/showthread.php?tid=8362) |
Item sought for the Archive - Archivist - 13-02-2023 Does anyone have a copy of the VSCC Bulletin, Summer edition 2008, No 260 that they would be prepared to donate to the archive, please? There is an Austin 7 based article that I would like to add to the colleection... thanks Hugh RE: Item sought for the Archive - Steve Jones - 14-02-2023 Are you wanting a full copy of the Bulletin or just a copy of the Norman Prince article, Hugh? Steve RE: Item sought for the Archive - Mike Costigan - 14-02-2023 If that is the issue with the Norman Prince article, then I gave you a copy of this issue a couple of years ago, plus the next one which had a follow-up article on his post-Austin experiences. They should be inĀ the Archive somewhere, Hugh. RE: Item sought for the Archive - Archivist - 14-02-2023 Doh! You are quite right Mike.. I was tidying up my email inbox which is beginning to threaten my capacity limit and was clearing out large emails. Yours had images of the Article and my request was 'fired from the hip' as one might say.. Note to self: check first... :o( Thanks for the offer Steve... Hugh |
