Photo in private message - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Photo in private message (/showthread.php?tid=8338) |
Photo in private message - Scarlet O'Hara - 06-02-2023 Hi all, is it possible to attach a photo to a private message sent from the forum? RE: Photo in private message - Ian Wegg - 06-02-2023 I've just tried it. There doesn't appear to be a method for attaching a photo in the same way as you can in a forum post. However, it looks as if you can embed any picture from another site using BBcode - i.e. enclosing the URL of the image between IMG tags. If the PM I sent you has a picture in it then it works! RE: Photo in private message - Scarlet O'Hara - 06-02-2023 Thanks Ian,picture received so it works. RE: Photo in private message - Reckless Rat - 06-02-2023 I will go with that. All you need is the .jpg link of the photo and cut & paste it between [img] and [/img] (without spaces of course). So if the link address is: (for example) https://i.postimg.cc/QtVDR2qm/IMG-20180801-WA0002.jpg when you stick it between [img] and [/img] you get this:- ![]() RE: Photo in private message - Chris KC - 07-02-2023 Presumably that only works for images which are hosted somewhere on the web, so no use if you want to send a pic of something you did in the garage this morning (unless you upload it somewhere first). RE: Photo in private message - Reckless Rat - 07-02-2023 Yep. You have to upload it to a server. I use www.postimages.org |
