Fitting bushes to rear centre blade - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Fitting bushes to rear centre blade (/showthread.php?tid=8327) |
Fitting bushes to rear centre blade - Graham5475 - 01-02-2023 Hi - can someone please advise how to fit the centre bushes into the centre blade on the rear shock absorber RE: Fitting bushes to rear centre blade - Parazine - 02-02-2023 Squeeze it in using a G clamp?? Assumes you've got the thing apart of course.... RE: Fitting bushes to rear centre blade - goodwoodweirdo - 06-02-2023 Nut and bolt and tighten ... just fitted mine last night RE: Fitting bushes to rear centre blade - JohnD - 06-02-2023 I done a pair last week, and they tapped in with a hammer, Just done the front yesterday and they also just tapped in. Sevenworkshop had no Nylon one's in stock, last week, does anyone else have these in stock? For the front i used a wooden one & a nylon one that i found in a box of bits - should be ok, but would change if i could find stock. RE: Fitting bushes to rear centre blade - Tony Griffiths - 07-02-2023 (06-02-2023, 01:13 PM)JohnD Wrote: I done a pair last week, and they tapped in with a hammer, Just done the front yesterday and they also just tapped in. David Cochrane has them in nylon. https://www.a7c.co.uk/aboutus.php I'm overhauling my rear dampers at the moment - and the bushes in mine are brass or bronze - presumably changed by somebody else. My through-pins were badly corroded so I bought a pair of replacements from David Cochrane - you just get the shaft and the fine thread with a flange on the end and not the "big washer". Hence it's necessary to drill out the old pin and fit the new one - though as various surfaces are corroded, a lathe is handy to get them cleaned up and a flat surface for the new pin's flange to sit against. I may silver-solder the replacements in as well. Has anyone else recently done this job? RE: Fitting bushes to rear centre blade - Steve Parkin - 08-02-2023 I did the front damper on our RN recently and after reconditioning the blades I fitted a new nylon bush -that just tapped in with no problems. For the record, sorting out the front damper made a big difference to handling. I just went for the standard parts from one of our cherished suppliers. |
