Mystery gearbox - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Mystery gearbox (/showthread.php?tid=8274) |
Mystery gearbox - winchman - 12-01-2023 Hello Would any one know what vehicle this is from? RE: Mystery gearbox - Peter Clayton - 12-01-2023 ls this be from a marine environment? what gears are there, just forward/reverse ? Does nor appear to have capacity for a clutch. RE: Mystery gearbox - Mike Costigan - 12-01-2023 I would guess a light car from the early 1920s; the drum is a transmission brake, and presumably the gearbox is located separately from the engine and clutch. The 'quality' of the gearchange lever suggests a relatively cheap car, but it's probably a proprietary unit which may be common to a number of vehicles. |
