Engine Re-build Completed Finally - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Engine Re-build Completed Finally (/showthread.php?tid=8255) |
Engine Re-build Completed Finally - Jamie - 30-12-2022 After what has seemed to be an eternity, I have completed the re-build of my Ruby engine. All being well, I shall get it to a friend's place in the next few weeks and give it a test run: he has a test bed with everything ready to hook up to start an engine. Thank you, everyone, who has answered my questions during the work or helped with parts. All I need to do now is to complete re-building the running gear, the chassis and the body. Regards, Jamie. RE: Engine Re-build Completed Finally - Hurvinek - 30-12-2022 Congratulations, Jamie! Hope it will run fine. And that's surely the the best way to reuse a Prosecco cork... well done! ? ![]() RE: Engine Re-build Completed Finally - JonE - 30-12-2022 Well done! Looking good. Your manifold studs - did you just use the longest standard sizes and make spacers accordingly? And what did you seal them with, out of interest? RE: Engine Re-build Completed Finally - Ruairidh Dunford - 30-12-2022 Nice work, Jamie. ![]() RE: Engine Re-build Completed Finally - Jamie - 31-12-2022 Hurvinek: thank you. The prosecco cork fitted perfectly and certainly has more style than the old sock stuffed up the exhaust manifold. Jon: Thank you. Originally , I was planning to fit the standard manifold, so just used the same studs, using old valve guides for spacers. I sealed them with some sort of Loctite, but I cannot remember which type. Ruairidhi: thank you. Jamie. |
