Valve guide choice - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Valve guide choice (/showthread.php?tid=819) |
Valve guide choice - AllAlloyCup - 12-02-2018 I have a block M 268616 which has had to replace the cracked 88xxx original Should I use either new plain guides or shouldered guides? Or does it not matter? Regards Bill G RE: Valve guide choice - Ruairidh Dunford - 12-02-2018 It is my understanding that you should fit the correct type for the block Bill. I presume you do not know what type were fitted originally? If you can take a picture of the underside of the valve chest, to show where they fit, I can tell you which it had originally. RE: Valve guide choice - Ruairidh Dunford - 12-02-2018 Edit - your new block certainly had straight followers originally. RE: Valve guide choice - AllAlloyCup - 12-02-2018 Thanks for the information Ruairidh. Straight ones came out, but the seats had recessess That looked as if shouldered ones would also fit. I have a set of straight ones that I’ll fit. Busy making alloy wings! Regards Bill G |
