Bacon slicer - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Bacon slicer (/showthread.php?tid=8169) |
Bacon slicer - Vancevr - 17-11-2022 I have the bacon slicer starter motor. I was having battery issues and tried to use the starter and it was slow and eventually stopped. After some time I wanted to investigate. And it wont spin even when bypassing the button. The brushes looked ok to my untrained eye. And both parts that spin spin fine but when I reasembled it only clicks when i give er juice. I tried to pry it around with a screwdriver its hard to spin. Any thoughts? RE: Bacon slicer - Howard Wright - 17-11-2022 Hi My first port of call would be the earth connection. Try running a separate earth directly from the battery to the starter. Cheers Howard RE: Bacon slicer - Vancevr - 17-11-2022 Where should i attach it to RE: Bacon slicer - Howard Wright - 17-11-2022 Hi Vancevr I don’t have a bacon slicer starter so I can’t answer too authoritatively but I would imagine anywhere on the main body, probably the mounting bolts would be a good place. Cheers Howard RE: Bacon slicer - Vancevr - 18-11-2022 i used the mounting nuts on the shifter cover. RE: Bacon slicer - Erich - 18-11-2022 Vancevr, by shifter cover, you mean the cover for the g/b? If so, you may not be getting the best ground, given the aluminum g/b housing. You might try a dedicated fixing on the floor pan or firewall. I'm certainly no auto electric expert, but a good ground is very important, that much I do know. ;-) Erich in Mukilteo RE: Bacon slicer - Tiger - 18-11-2022 It shouldn’t be hard to spin ! Take the starter off and investigate could be dry bearings RE: Bacon slicer - bob46320 - 18-11-2022 Bent armature spindle - but you said it spins OK off the vehicle. Brush flexible cable loose fitting onto screwed terminal or solder joint (at other end) to the field winding has burnt out. |
