Track Rod End Screw Thread - Printable Version
+--- Thread: Track Rod End Screw Thread (/showthread.php?tid=8083)
Track Rod End Screw Thread - Chris KC - 06-10-2022
I believe the track rod end adjustment thread is 3/4" x 20 tpi - would I be correct in guessing it's Whitworth thread form rather than BSC? Anyone know please?
RE: Track Rod End Screw Thread - Charles P - 07-10-2022
(06-10-2022, 10:23 PM)Chris KC Wrote: I believe the track rod end adjustment thread is 3/4" x 20 tpi - would I be correct in guessing it's Whitworth thread form rather than BSC? Anyone know please?
Pretty certain it's whitworth.
I have a die if you want to borrow one
Charles
RE: Track Rod End Screw Thread - blackshed - 07-10-2022
3/4" 20tpi  is a Cycle Tread as far as I know
RE: Track Rod End Screw Thread - Chris KC - 07-10-2022
(07-10-2022, 04:25 PM)blackshed Wrote: 3/4" 20tpi  is a Cycle Tread as far as I know
Tracy Tools' website offers 3/4" x 20 in both BSC and Whitworth thread forms.
The two are different though (BSC is a 60 degree tooth angle vs 55 for Whitworth).
Charles
Thanks Charles - I've sent you a p.m.
RE: Track Rod End Screw Thread - Chris KC - 13-10-2022
Just for closure, Charles very kindly lent me his whitform thread die and the new thread is indistinguishable from old by eye.
The job is now done, back on the car and functioning.
Charles, I have p.m.'d you - don't forget to send me your return address!!
