Supercharged Ulster revcounter drive gears - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Supercharged Ulster revcounter drive gears (/showthread.php?tid=808) |
Supercharged Ulster revcounter drive gears - Austin in the Shed - 09-02-2018 I am having a small batch of these gears made now to suit the casings I make. They are awkward gears to make as the one driven by the camshaft ,6 tooth is cut at a steep angle and needs a particular machine to be able to cut it.There is turning,milling,gear cutting,spark erosion,heat treatment, and grinding involved and the cost would be around £145 -150 a pair. Is there anyone who would like any extra gears for their cars while I am getting them done.I would need to know quickly as they are now in process. Please PM me if you need some. RE: Supercharged Ulster revcounter drive gears - Austin in the Shed - 28-08-2019 I have some of these gears now,Anyone need them. I can't find the emails / PM's I received from then. PM please if intereseted |
