Ignition wiring - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Ignition wiring (/showthread.php?tid=8022) |
Ignition wiring - Campbell Sutton - 11-09-2022 Hi everybody, I have a late 1928 A7 chummy, (first of the coil ignition) I am currently tidying up the wiring and I noticed the ignition feed has been wired off the bacon slicer starter switch. I took the starter switch out to inspect and it was covered in oil, which would explain the sluggish starter motor. My question is should the ignition be wired off the early baconslicer or directly back to the 6v battery? I know the later cars with foward facing starter were wired like this, however the switch was not exposed to oil etc from flywheel. My gut tells me oil on the ignition feed contact would add resistance and effect voltage output. RE: Ignition wiring - stuartu - 11-09-2022 It would appear that Longbridge's guts were aligned with yours. The answer can be found in one of the wiring diagrams here: http://www.da7c.co.uk/technical_torque_articles/A7%20Wiring.pdf As a matter of almost equal interest, I wonder if the amount of oil on your starter switch is significant? Perhaps it has accumulated over aeons or perhaps it might bear further investigation in due course. Regards, Stuart RE: Ignition wiring - goodwoodweirdo - 12-09-2022 stuartu, many thanks for sharing the link / pdf RE: Ignition wiring - Campbell Sutton - 12-09-2022 Thanks Stuart, that makes good sense. Regards Campbell Sutton RE: Ignition wiring - k8207418 - 12-09-2022 Some info here Wiring Info https://www.austinsevenfriends.co.uk/forum/showthread.php?tid=7891&pid=86437&highlight=Wiring+info#pid86437 RE: Ignition wiring - John Cornforth - 12-09-2022 Hi If the ignition feed is taken from the battery side of the starter switch (as per early 30s onwards), the state of that switch won't affect the ignition but could of course affect the starter. Engine oil is a pretty good insulator, so it's no problem if it coats the outside of a terminal as long as it doesn't actually get between the contacts. This won't happen with a "nut and bolt" connection if it's bolted up properly. Even battery terminal contact faces can be very lightly smeared with vaseline after they have been cleaned but before assembly. Even though its an insulator it gets squeezed into the gaps when you bolt it up and the microscopic high points still touch each other to give a good contact. The vaseline keeps out air and moisture, which reduces any tendency to corrode. |
