High torque 12V starter motor experience - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: High torque 12V starter motor experience (/showthread.php?tid=7901) |
High torque 12V starter motor experience - dchw1975 - 12-08-2022 Hi, The forward facing starter motor on my special has decided that the long cranking to pre circulate oil (~20s as I have an external oil filter that drains back)is too much and stopped working. I was wondering if anyone on the forum has experience of replacing the older motors with something like https://www.holden.co.uk/files/081_1090.pdf , a modern very compact motor? Positives and negatives please Cheers David RE: High torque 12V starter motor experience - Terrytuned - 12-08-2022 Have fitted several of these to race engines with no proplems and being prengaged you won't have any ring gear wear. Terry RE: High torque 12V starter motor experience - Charles P - 12-08-2022 I have something like that. I spent some time looking at the Denso starter catalogue and discovered that the Rover 75 V6 petrol starter motor has an exceptionally long reach, rotates the right way and has the useful interchangeable Denso multi-splined pinion. I trimmed the excess mounting points from the front of the starter motor casting, made an adapter from 12mm aluminium to bolt the starter to the 30/31 mounting, on the right register. I sourced the nearest match in diameter and tooth count for the pinion, swapped that over and bobs your uncle. Then I painted it all black, to disguise it deep under the scuttle. Total cost less than £50. RE: High torque 12V starter motor experience - flywheel1935 - 12-08-2022 Just spotted the flaw in the holden advert, It says direct replacement, but it's 12 volt, ahum ???? RE: High torque 12V starter motor experience - winchman - 13-08-2022 (12-08-2022, 11:02 AM)Charles P Wrote: I have something like that.This would be good written up with photos. Back to the OP my only experience of larger starters was a massive difference for the better on an old Picasso Diesel, high torque starter made it like a new car RE: High torque 12V starter motor experience - Charles P - 13-08-2022 (13-08-2022, 10:02 AM)Owinchman Wrote:(12-08-2022, 11:02 AM)Charles P Wrote: I have something like that.This would be good written up with photos. Sorry, just did it without taking photos. Anyone with a lathe and some engineering common sense should be able to work out the plot. The only thing to be careful about is the motor orientation ensuring that the gearstick can't bang into the positive terminal. It's unlikely but if the stick hits the terminal when you've pressed the starter, it all gets a bit November 5th Charles |
