Zenith F - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Zenith F (/showthread.php?tid=7865) |
Zenith F - Ray White - 04-08-2022 I have a Zenith F carburettor that I understand was fitted to Austin Sevens from 1923 to 1926. Apart from the choke spring having broken (and temporarily bodged) it seems to be in good unrestored condition. I have been advised that the shield which I added is incorrect but as there was an unused threaded hole I assumed there should be one. The essential difference between the F and the more commonly seen FZ is the bottom feed to the float chamber as opposed to a side entry. A rare carb? ![]() ![]() ![]() RE: Zenith F - David Cochrane - 05-08-2022 I think this version was only fitted in 1923. RE: Zenith F - Ray White - 05-08-2022 A very limited market then? |
