Sender float arm - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Sender float arm (/showthread.php?tid=7846) |
Sender float arm - richard tatton - 01-08-2022 Is there a method of removing the arm of my petrol float from the sender, preferably without using heat. I have a cork float which I fear will disintegrate in the modern fuel and would like to replace it with a float from another u/s sender unit.Thanks for any advice RE: Sender float arm - "Slack Alice" Simon - 01-08-2022 I couldn't do it, I suspect it might be silver soldered. I bought a brass float off Ebay and soldered it in place of the disintegrated original. |
