Window regulator channel - Printable Version
+--- Thread: Window regulator channel (/showthread.php?tid=7754)
Pages: 1 2
Window regulator channel - Jason Franzone - 19-07-2022
Hi all. A little bit of advice needed.
Is anyone making or selling the channel that for a Mk 1 Ruby is fixed to the glass on the side windows that the regulator slides back and forth on the to raise and lower the window?
I have one complete and one that is sort of half missing.
Any help much appreciated.
Jason
RE: Window regulator channel - Andy Bennett - 19-07-2022
Hi Jason
you might want to wait until some of our cherished suppliers are back from the centenary event to ask your question as people like Tony Betts may have something in his shed.
Andy
RE: Window regulator channel - Jamie - 19-07-2022
Is it R37 on this page?
http://www.oxfordshiresevens.co.uk/ruby-body-panels-and-parts/
Regards,
Jamie
RE: Window regulator channel - Jason Franzone - 19-07-2022
Yes! Well I assume so. The description sounds right.
Thanks Jamie.
Cheers,
Jason
RE: Window regulator channel - Martin Prior - 20-07-2022
Hi Jason. I assume that you're referring to the steel channel that's actually part of the door, or were you thinking of the felt-lined rubber channel that fits inside it?
RE: Window regulator channel - andrew34ruby - 20-07-2022
(20-07-2022, 04:43 PM)Martin Prior Wrote: Hi Jason.  I assume that you're referring to the steel channel that's actually part of the door, or were you thinking of the felt-lined rubber channel that fits inside it?
He says the bit that is fixed to the glass.
RE: Window regulator channel - Jason Franzone - 20-07-2022
That’s correct. The channel that fixes to the glass.
RE: Window regulator channel - Jason Franzone - 15-11-2022
Does anyone have one of these they wish to sell? Not getting a response from Oxfordshire sevens.
RE: Window regulator channel - John Cornforth - 15-11-2022
Hi
Would this classic VW Beetle item be any good ?
https://www.megabug.co.uk/window-lifter-channel-vw-beetle-1952-to-1964-1473-p.asp
RE: Window regulator channel - Jason Franzone - 16-11-2022
It looks close but not sure the channel for the roller is long enough
