SCREWS BODY TO WOOD - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: SCREWS BODY TO WOOD (/showthread.php?tid=7605) |
SCREWS BODY TO WOOD - Dennis Nicholas - 09-06-2022 What wood screws best to use where body is being screwed onto Ash wood parts? (mild steel with wax in hole; brass + wax; stainless + wax)? Dennis RE: SCREWS BODY TO WOOD - Ivor Hawkins - 09-06-2022 I only ever use stainless screws as a last resort, but after snapping three brass screws in the ash framework, I went to the stainless, without wax, incidentally. Just my experience, but it worked for me. RE: SCREWS BODY TO WOOD - Stuart Joseph - 09-06-2022 If using Brass or Stainless Steel woodscrews use a pilot drill then insert a steel screw of the same size first (lubricated with soap). This will reduce the chances of brass or SS screws breaking. Regards from the creative county - Staffordshire RE: SCREWS BODY TO WOOD - Hugh Barnes - 09-06-2022 I have always understood that brass screws will break. Not necessarily during fitting, but later when vibration hardens them and they snap under any pressure.. I also have it in the back of my mind that there is a reason not to use SS as well. I would always reach for steel.... |
