charging a 12V battery that is down to 7.5V - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: charging a 12V battery that is down to 7.5V (/showthread.php?tid=7579) |
charging a 12V battery that is down to 7.5V - JonE - 01-06-2022 I rescued an old Yuasa 45AH 325A ?aircraft battery from inlaws' house. I've tried to put it onto a Lidl smartcharger but it won't even start on its ramping cheeses display. What would you advise? 7.5V reading, but its one of those ones with no fill possible. I have a standard car battery charger too. The battery says do not exceed 4.2A charge or 10 hours charge, but I'd have thought that something tiny would be much better? RE: charging a 12V battery that is down to 7.5V - Reckless Rat - 01-06-2022 I think you'll find it has failed under constant kineticism + excessive discharge RE: charging a 12V battery that is down to 7.5V - JohnD - 01-06-2022 Set of jumpleads off the car onto the battery, let car idle for 15-20min then stick battery charger back on, it will probably have enough in it then for the electronics to regognise it RE: charging a 12V battery that is down to 7.5V - JonE - 02-06-2022 thanks - nothing to lose John, so will try before considering consigning to skip...! |
