Low charging generator - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Low charging generator (/showthread.php?tid=7508) |
Low charging generator - SneezerUSA - 13-05-2022 My generator appears to have a charging problem in that it is only putting out about 2 to 2.5 volts. Pulled the inspection cover and the brushes appear to be new. Cutout functions. ANY IDEAS? Arnie RE: Low charging generator - john williams - 13-05-2022 The cut out will not function at 2-3 volts. Disconnect both leads at"D" and "F" terminals on dynamo. Bridge the "D" and "F" terminals with a short cable. Run the engine, dynamo should produce 7.5 volts. If it only produces 1.5 -3 volts, fault is in field circuit in dynanamo. If dynamo produces 7.5 volts, fault is in wiring or cut out. RE: Low charging generator - Bob Culver - 13-05-2022 Presumably mean amps? Is it a first run or just occurred? Is the wirng somehow configured so the summer resistor remains in and unbridged? Shorting F and D as above but keeping dyn connected should produce full amps. RE: Low charging generator - SneezerUSA - 14-05-2022 As I am electrically challenged, I will disconnect both wires and create a bridge.After that I assume I need to connect a multimeter to see what the output actually is. Photo f my generator attached. RE: Low charging generator - Bob Culver - 14-05-2022 It is a 1933ish 35A dynamo. One wire is the Field and one the output, fathomable by removing hte cover. The output goes dirct to a large brush. The coiled resistor if inatct feeds a reduced voltage to the the field for Summer. For Winter, lights on etc, the dashboard switch directly links the two wires, assuming the field wire is continuous to that point. Apart from brief testing the dyn must not be run without the external connection (eventually to battery thru operated cutout) RE: Low charging generator - SneezerUSA - 14-05-2022 Thanks for the replies. Is it possible that the two wire are switched?. I rewired the entire car as it was when I purchased it last Fall. It took me all Winter to bring the car back from the DEAD as so much questionable work had been done on it during the prior owners "RESTORATION". RE: Low charging generator - Tiger - 14-05-2022 Hello Not sure if your Dynamo has worked for you earlier If it is some time since working it will probably need polarising. There are lots of post to help with this and other charging faults on the forum. However lots of info. I used is from the Cornish Austin Site find through Google Also Harry Hales produced a marvellous booklet also on the forum. Happy to help further if you need it. Regards Tim RE: Low charging generator - Jeff Taylor - 14-05-2022 Here's the link to the Cornwall Austin Seven Club's Technical Articles / Electrical and Ignition. http://www.austin7.org/Technical%20Articles/#Electrical |
