Brake lights - Printable Version
+--- Thread: Brake lights (/showthread.php?tid=7463)
Brake lights - Paul Govier - 02-05-2022
I'm seeking some help / advice...
Which is the the best way to install brake lights onto a SWB coupled brakes car? ..and which is the most appropriate brake light switch to use?
Any instructions (and photos ) would be greatly appreciated.
Many thanks.
RE: Brake lights - Reckless Rat - 02-05-2022
You can get a brake light switch from our cherished suppliers. Mount it on the front crossmember with a long spring from the switch pull-rod to the brake rod from the cross-shaft to the foot pedal. There is a little clamp to go round the brake rod, with a small hole to hook the spring into. That then gives you scope to adjust the moment the brake lights activate.
BG307a by Dave Cochrane will do just fine (www.a7c.co.uk)
