6v cutout relay/control box - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 6v cutout relay/control box (/showthread.php?tid=7421) |
6v cutout relay/control box - Jerrybean7007 - 23-04-2022 Hey guys, I live in Cape Town, South Africa and parts are hard to find here. I have a project A7 Ruby that needs a voltage regulator but I can only find 12v regs. The only 6v reg that I can find is currently on my 1934 Nippy and I can't butcher my pride and joy in order to resurrect my basket-case Ruby. Is there anything you can suggest to solve my problem? I wonder if it would hurt to try a 12v regulator on the car since the generator would only be producing about 7v anyway. Regards. Jeremy RE: 6v cutout relay/control box - Greig Smith - 23-04-2022 Welcome Jeremy, I'm just up the coast from you in PE Sent you a PM Aye Greig RE: 6v cutout relay/control box - Denis Sweeney - 23-04-2022 If you are looking for a 6v Lucas CFR2 Regulatir which I have on my Ruby, Dynamo Regularor Conversion stock New Old Stock units. RE: 6v cutout relay/control box - Nick Salmon - 23-04-2022 Or a Lucas RB 106 12v and pull back the third brush. RE: 6v cutout relay/control box - John Cornforth - 23-04-2022 Hi Jeremy The standard setup for a Ruby is a 6 volt "Third Brush" generator. This does its own regulation (after a fashion) so it doesn't actually need a Regulator in the full sense of the word, just a Cut-Out plus a half charge resistor controlled by the Lighting/Charging switch. One possibility is to use a modern power diode in place of the Cut-Out, a Schottky type is best as it only drops about half a volt. A current rating of say 20 Amps or more would suit. It might benefit from a small heatsink as it will dissipate a few watts. All the cutout or diode does is to stop current flowing back from battery to dynamo when revs are low or the engine is stopped. The half charge resistor can be replicated with a modern power resistor, it needs to be about 1.5 ohms and rated at about 5 watts. Build both these components into an old empty cutout or regulator box and you will keep a period look. RE: 6v cutout relay/control box - Jeff Taylor - 24-04-2022 Link to 'Classic Dynamo & Regulator Conversions Limited' based here in the UK as mentioned by Denis Sweeney in his above post. http://www.dynamoregulatorconversions.com RE: 6v cutout relay/control box - Bob Culver - 24-04-2022 With modern batteries voltage regulation is desirable as not supposed to exceed 14.6/7.3 volts. Most extensivley use the Summer charge(or remove fuse so none) for day running and rely largely on a modern permanent intelligent bench charger. I cannot see why a suitably configured 6v electromechanical regulator cannot be used, with 3rd brush adj to not exceed about 8amps charge lights off. 12v electro mechanical regulators have been used but the types also with current reg probably will not adjust down to 8 amps so the 3rd brush is set to provide this maximum. On a 6v dyn with original field winding twice the normal field current is switched so short contact life is reported, and the field winding, maybe ditto. |
