Ruby gasket - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Ruby gasket (/showthread.php?tid=7277) |
Ruby gasket - Tiger - 12-03-2022 Need to buy nose cone gasket for my Ruby. But can’t see one listed on the seven workshop. Anyone know a supplier ? Regards Tim RE: Ruby gasket - Bryan - 13-03-2022 David has them. Part BA120 https://www.a7c.co.uk/ Regards Bryan RE: Ruby gasket - Derek Sheldon - 13-03-2022 Find some stiff card and cut your own. Cereal box RE: Ruby gasket - Steve kay - 13-03-2022 Does that actually work? Does the card need to be soaked in oil, thuogh probably not marinated in olive oil? RE: Ruby gasket - Howard Wright - 13-03-2022 Hi Tim and Steve Gasket paper is available cheaply and is easy to cut with scissors and a punch. Marking out can be tricky but I “blue” the component face then press onto the paper for a good imprint. No need to soak but I do smear the lightest layer of Hylomar on both sides of a joint like this. Be careful though some joints are gasket thickness sensitive and the dynamo housing to crankcase is one of them. Too thick a gasket can increase the backlash on the dynamo gear, too little and it will mesh too tightly. I don’t think the nose cone is thickness sensitive. Cheers Howard RE: Ruby gasket - Hedd_Jones - 13-03-2022 (13-03-2022, 09:01 AM)Steve kay Wrote: Does that actually work? Yup. I've heen doing it 25 years. 3rd generation in our family to do it. Works great RE: Ruby gasket - john williams - 13-03-2022 Howard, for the April Club Night, I will demonstrate the practice of making gasgets using a steel ball bearing and a "toffee hamer". No scisors need. Perhaps someone will record it on their phone, and we can add it to SWA7C web page. John RE: Ruby gasket - Howard Wright - 13-03-2022 (13-03-2022, 11:57 AM)john williams Wrote: Howard, for the April Club Night, I will demonstrate the practice of making gasgets using a steel ball bearing and a "toffee hamer". No scisors need. Hi John Good idea, Thanks Cheers Howard RE: Ruby gasket - Tiger - 13-03-2022 Many thanks for the replies and useful tips. Going to order one on Monday Regards Tim RE: Ruby gasket - Derek Sheldon - 14-03-2022 I’ve taken the ball bearing thing one step further, I welded one to the end of an old punch. I punch my first hole and drop an appropriate bolt in the hole, do the second , then small hammer tapped around the item to mark the edges in and out. Finish with scissors. By the way, I have an old photo album that supplies lovely paper for gaskets. Seal with Hylomar |
