Petrol sender access panel - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Petrol sender access panel (/showthread.php?tid=7226) |
Petrol sender access panel - Mick Hanna - 27-02-2022 Today I cut a hole in the floor pan of my Ruby to gain access to the sender unit on top of the petrol tank. It was a very tense experience considering there is only about a 4-5cm gap between the floor and the top of the tank. I had to place a baking tray on top of the tank to protect it from the vicious 102mm hole saw. It generated a few alarming sparks and smoke. Not a job I would like to repeat, but it will beat scrabbling around underneath the car when I get round to fixing the sending unit! RE: Petrol sender access panel - Duncan Grimmond - 27-02-2022 I think I would have used a block of wood to help keep the pilot drill of the hole saw a bit more steady...still, you got it done with a neat finish and you won't regret it! RE: Petrol sender access panel - Mick Hanna - 28-02-2022 I meant to post this on the 'What have you done with your Austin today' thread. |
