Trouble sealing a Ruby windscreen - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Trouble sealing a Ruby windscreen (/showthread.php?tid=7143) |
Trouble sealing a Ruby windscreen - Denis Sweeney - 02-02-2022 I fitted a new seal on the windscreen of Ruby about 3 years ago and at the time all seemed good, but the rubber no longer has any resilience or elasticity and now no longer seals the gaps around the screen, there is a clear gap virtually all the way around but is particularly bad in each of the four corners. Searching back to the previous Bravenet days of this forum where there were posts with pics showing exactly the same problems that I have now. Has anyone else had this problem in recent times and if so has anyone come up with a suitable solution?? Cheers RE: Trouble sealing a Ruby windscreen - john williams - 02-02-2022 I use black self adhesive neoprene foam strip around the surface of the windscreen aperture of the car body. When you then close the windscreen it clamps onto the neoprene foam strip. John RE: Trouble sealing a Ruby windscreen - Denis Sweeney - 02-02-2022 Hi John, sorry if this is dumb question but is that in addition to the screen seal or instead of? Cheers RE: Trouble sealing a Ruby windscreen - Ivor Hawkins - 02-02-2022 Denis, there is a product called Armor All, I’m not sure whether you can still get it but it revitalised and protects rubber, Ive used it in the past to great effect. RE: Trouble sealing a Ruby windscreen - john williams - 03-02-2022 As well as. The rubber seal fixed around the frame, seals against the neoprene foam. It is possible to fit the neoprene foam, so that it is barely visable with the windscreen shut. John RE: Trouble sealing a Ruby windscreen - Denis Sweeney - 03-02-2022 Thanks John RE: Trouble sealing a Ruby windscreen - andrew34ruby - 03-02-2022 My early Ruby has the original rubber surround and has large gaps. I have found that it just doesn't matter. Through flow ventilation! RE: Trouble sealing a Ruby windscreen - Denis Sweeney - 03-02-2022 I’d probably feel the same way but we’re going on the centenary round trip tour to France Belgium and Germany, not sure her indoors and navigator in chief will be too pleased with a few gallons of water being dumped on her lap during any inclement weather………. ??? |
