RP door handle removal - Printable Version
+--- Thread: RP door handle removal (/showthread.php?tid=7129)
RP door handle removal - SneezerUSA - 29-01-2022
Can someone tell me the SECRET of how the window crank is removed?  Look easy but I've had no luck so far.
RE: RP door handle removal - Howard Wright - 30-01-2022
Hi
This thread may help
https://www.austinsevenfriends.co.uk/forum/showthread.php?tid=794&pid=6710&highlight=Window+winder#pid6710
RE: RP door handle removal - Henry Harris - 30-01-2022
(29-01-2022, 11:47 PM)SneezerUSA Wrote: Can someone tell me the SECRET of how the window crank is removed?  Look easy but I've had no luck so far.
Press the escutcheon to the left, compressing the small spring that can be seen in your pic and the handle should pull off.
RE: RP door handle removal - SneezerUSA - 30-01-2022
Someone has been at the spring before and it will not retract due to being distorted. Removed spring and handle still does not come off. Starting to think crrosion between the pot metal and steel shaft. Any more idea appreciated.
RE: RP door handle removal - Andy Bennett - 31-01-2022
on my RP the chrome door cover disk also has a spring so you push towards the door and a pin hole appears through the shaft and handle. Mine was secured with a crude piece of wire poked through.
RE: RP door handle removal - Lowespeed - 31-01-2022
This looks like the RN type handle. The rear bezel / escutcheon is spring loaded and has a D shaped hole. You slide it away from the handle end and pull it off the spindle. There is a "bar" inside the hole that fits on the spindle that does the driving of the mechanism. This fits into a cut out on the end of the spindle with a spring loaded ball in it.
RE: RP door handle removal - Steve Parkin - 01-02-2022
I spent a lot of time thinking about how to get a similar handle off the door of our RN. I also did some searching on-line for the various possible methods.
In the end I got a wire frame coat hanger and used the hook to loop around the handle and with one swift tug on the spigot it came right off. I didn't even need to alter the profile of the hook. I have kept the coat hanger in the garage for the next time.
Perhaps a thread on uses for wire coat hangers wouldn't go amiss.
