Fly off handbrake - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Fly off handbrake (/showthread.php?tid=7121) |
Fly off handbrake - shane - 28-01-2022 I would like to put a period-looking fly-off handbrake onto a single seat special with an offset rear axle. Has anyone done this before? RE: Fly off handbrake - Greig Smith - 28-01-2022 We fitted a simple pull hand brake to our offset single seater, but there's no reason why a bracket to suit a fly-off handbrake couldn't be made / adapted. The hand brake was positioned on the chassis rail where it was most comfortable to reach it - It actuates the cross shaft via a short linkage as can be seen in the picture below. It moves fore & aft with the brake pedal as it's linked to the cross shaft. We modified the ends of the cross shaft to take rod rears instead of cables and Dad re-made a Bowdenex conversion for the fronts. The hand brake came out of the parts bin as we re-purposed a lot of stuff. Aye Greig RE: Fly off handbrake - stuartu - 28-01-2022 Two of my cars have fly off handbrakes, one of which I made myself. The cars are occasionally used in mild competition. I presume your single seater will not be a road car. Both cars have a system which uses a button on top of the lever to push the pawl into the ratchet. This works perfectly well in relatively unstressed conditions (road use, parking etc.). I am not the only person to find that in conditions of greater stress, such as on a start line however humble, the habit of a lifetime in other road cars takes over and one presses the button down in a mistaken attempt to disengage the ratchet. I'm sure you would never do this. If I used a car solely for competition I would eschew the fly off feature and contrive a simple detente for use when parking. Or use a chock. Regards, Stuart RE: Fly off handbrake - shane - 29-01-2022 Thanks for the advice guys RE: Fly off handbrake - Alan - 29-01-2022 In 40 odd years of hill climbing, I can’t remember ever using my handbrake off the start. I wouldn’t worry about it. RE: Fly off handbrake - Erich - 29-01-2022 You could also go the 'Nash route and fit a handle but use a leather strap to set the brakes. Erich in Mukilteo |
