Body to chassis packing thickness - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Body to chassis packing thickness (/showthread.php?tid=7096) Pages:
1
2
Body to chassis packing thickness - Steve Bryant - 19-01-2022 Does anyone know the original factory thickness of the body packing between the steel floor and the chassis body supports? Thanks, Stephen RE: Body to chassis packing thickness - Jamie - 19-01-2022 Which model car? If it is a Ruby, I can measure mine in the morning. The body is off at the moment and the blocks are readily to hand. RE: Body to chassis packing thickness - Steve Bryant - 20-01-2022 This would be for a 1929 AD bodied Chummy / Van. Stephen RE: Body to chassis packing thickness - Jamie - 20-01-2022 Ah. Sorry, but I cannot help with that model. RE: Body to chassis packing thickness - Ruairidh Dunford - 20-01-2022 Packing pieces were made to fit the spaces - hence "packing". Altering these correctly can have a marked improvement of door and bonnet fit. RE: Body to chassis packing thickness - Steve Bryant - 20-01-2022 I understand that Ruairdh, but I am wondering if when new the cars had pads or material on all the contact points where the body sat on the chassis mounts. If so what would the materials thickness have been? RE: Body to chassis packing thickness - Tiger - 20-01-2022 Fitted packing pieces to my Ruby a while ago. Each Fitted to the space tightly as suggested by Ruairidh. Not sure how the original thickness would be relevant now ? RE: Body to chassis packing thickness - Ruairidh Dunford - 20-01-2022 (20-01-2022, 01:28 PM)Steve Bryant Wrote: I understand that Ruairdh, but I am wondering if when new the cars had pads or material on all the contact points where the body sat on the chassis mounts. If so what would the materials thickness have been? That would be entirely dependant on the individual characteristics of each chassis and body. RE: Body to chassis packing thickness - Malcolm Parker - 20-01-2022 I've always used strips of 3mm thick foamex plastic which is impervious to water and oil and also is slightly compressible. You could double it up if necessary but if you needed to do that I would question whether your chassis is true. The standard steel Austin floorpan is not very rigid and will pull down easily when bolted onto the chassis. It is what then happens to the door and bonnet fit that can cause problems. I would start by using single 3mm thick packers and see what happens. It's not an exact science, if it looks okay when finished it is alright! RE: Body to chassis packing thickness - Steve Jones - 20-01-2022 Unsurprisingly, I agree with Malcolm and use strips of the same foamex plastic (that he gave to me!!). Steve |
