Block date - Printable Version
+--- Thread: Block date (/showthread.php?tid=7092)
Block date - Brice - 18-01-2022
Is it possible to date a block from the serial number? If so what might the number 98048 roughly indicate?
Many thanks.
RE: Block date - Chris Garner - 18-01-2022
October 1929
RE: Block date - Colin Morgan - 18-01-2022
Quite a few blocks have a date case into them - mine carries the date 5th February 1937.
RE: Block date - Brice - 18-01-2022
Thank you Chris, and Colin. I have another block with a 1929 date clearly marked on it, though nothing on this one. So the block numbering simply follows crankcase numbering?
RE: Block date - Parazine - 18-01-2022
Where is the number you quote? On earlier (vintage) blocks, the engine number was stamped on the bottom lip of the valve chest. Intermediate blocks (1932 on?) carried no number but the late Ruby blocks (1937 on) had a platform in the casting above the water manifold, where the engine number was stamped. As has already been stated, engine number 98048 dated from October 1929, is this the number on your crankcase as well?
In all vintage engines, every major component carried the engine number. It makes spotting engines built from bits vs. those with all their original parts easy.
Exactly, bottom lip of the valve chest, and no it does not match the crankcase, far from it.
Thank you Parazine.
