ML Magneto Advance lever - Printable Version
+--- Thread: ML Magneto Advance lever (/showthread.php?tid=7062)
ML Magneto Advance lever - Charles P - 10-01-2022
Does anyone have the key dimensions of the throttle shaft mounted advance lever for an ML magneto (or even a spare one that they'd part with)?
Thanks
Charles
RE: ML Magneto Advance lever - Robert Foreman - 10-01-2022
Here you go Charles,
   this is a reproduction arm machined at the correct centres.
RE: ML Magneto Advance lever - Charles P - 10-01-2022
Perfect. Thanks Robert
