4 speed g'box speedo drive - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 4 speed g'box speedo drive (/showthread.php?tid=7035) |
4 speed g'box speedo drive - Hugh Barnes - 02-01-2022 I'm just finishing the refurb of a 4 speed Crash gearbox for the Box Saloon. I have only just realised that the box, rudely awakened from its slumbers of 30 years under the bench, has no speedo drive. Am I right in thinking that all 4 speeed boxes have the same speedo drive fitted, so I can scavenge one from anything? RE: 4 speed g'box speedo drive - dickie65 - 02-01-2022 The sports box has a different drive ratio for the speedo due to lower axle ratio. The crash box and early synco boxs should work for you. RE: 4 speed g'box speedo drive - Tony Betts - 03-01-2022 hi hugh. my memory is not the best, BUT several years ago i done a batch of NEW final drive gears for 3 and 4 speed boxes. but i think, the crash box was different to the syncromesh. ??? so i made the syncro,a NOT the crash. as the need was not asked for. it may be the crash is 7 teeth,without the 3 speed peg on the bottom. and the syncro is 8 teeth. but do excuss me on this because my memory may be wrong. im sure someone can confirm any differences. tony. RE: 4 speed g'box speedo drive - Ruairidh Dunford - 03-01-2022 (02-01-2022, 10:24 PM)dickie65 Wrote: The sports box has a different drive ratio for the speedo due to lower axle ratio. I always thought is was the speedometers that differed. Hugh, I can help you with the drive you need. RE: 4 speed g'box speedo drive - dickie65 - 03-01-2022 The EB65 speedo had the cable drive coming in a different angle. The speedo drive gears have a different part number on the sports models. When I ran a Box Saloon axle for a while the speedo was under reading by a lot. With the sports ratio axle back in its very accurate against a GPS. RE: 4 speed g'box speedo drive - Austin in the Shed - 03-01-2022 With a bit of cutting about you can get the cable to point upward if you are fitting into an earlier car. RE: 4 speed g'box speedo drive - Hugh Barnes - 03-01-2022 Thanks, all, for the pointers, I now can move forward and compete the 'box... |
