Ruby carb jetting change running on SWB? - Printable Version
+--- Thread: Ruby carb jetting change running on SWB? (/showthread.php?tid=6988)
Ruby carb jetting change running on SWB? - JonE - 19-12-2021
Has anyone found that the Ruby sidedraft Zenith has benefited from different jetting when running on a smaller lighter earlier car? Would be interested to hear any experimentation.
RE: Ruby carb jetting change running on SWB? - AustinWood - 19-12-2021
Sounds unlikely.
RE: Ruby carb jetting change running on SWB? - Howard Wright - 19-12-2021
Hi Jon
My opinion (and it is just that) is that carb set up is fully dependent on engine characteristics and not on the weight of the car!
RE: Ruby carb jetting change running on SWB? - Ivor Hawkins - 19-12-2021
Hi Jon, I ran a three bearing motor in a Chummy for years on the standard Ruby jetting and it ran perfectly, with a good plug colour and excellent fuel consumption.
If it ain’t broke...!
RE: Ruby carb jetting change running on SWB? - JonE - 19-12-2021
good. that's what I need to hear. Thanks all.
RE: Ruby carb jetting change running on SWB? - Bob Culver - 19-12-2021
Exhaust sytems affect optimum jets . For some reason unobstructed sytems seem to run more rich. Side exit possibly represent such. My RP feell from 50 to 40 mpg when a lightly baffled silencer fitted.
