Side water manifold studs - Printable Version
+--- Thread: Side water manifold studs (/showthread.php?tid=6980)
Side water manifold studs - "Slack Alice" Simon - 17-12-2021
What is the thread tapped into the block for the studs that hold the side water manifold?
BSF or Whit?
Thanks
RE: Side water manifold studs - Tiger - 17-12-2021
I think from memory it’s BSF.
NEXT TIME IN THE GARAGE I WILL CONFIRM
Yes I can confirm it’s 5/16” BSF
NOT sure if all engines the same.
That’s a 3 bearing Ruby
RE: Side water manifold studs - Howard Wright - 17-12-2021
(17-12-2021, 01:06 PM)Tiger Wrote: I think from memory it’s BSF.
+1
I’ve just installed a side branch on a 1930 engine.
RE: Side water manifold studs - "Slack Alice" Simon - 17-12-2021
Thanks
