car support - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: car support (/showthread.php?tid=6934) |
car support - Colin D Smith - 03-12-2021 Hi chaps Where would the best place to support the car so I can drop the front axle assembly? Mosts if not all the bushing needs replaced and I think I may have to take a look at the leaf spring. Help and advice needed as always. ![]() RE: car support - Rick F - 03-12-2021 I would support the chassis on two axle stands, just behind the chassis nose piece. RE: car support - dickie65 - 03-12-2021 I always put axle stands under the crossmembers below the chassis rails where it is strongest. The other place if your stands are tall enough is under the chassis rails inside the triangle formed by the radius arms, this makes it harder to roll the front suspension out on the wheels as the radius arms have to come off first. RE: car support - Colin D Smith - 03-12-2021 Thanks Chaps RE: car support - Howard Wright - 03-12-2021 (03-12-2021, 05:54 PM)Rick F Wrote: I would support the chassis on two axle stands, just behind the chassis nose piece. +1 from me. If your car is a light Special then supporting it on the cross member could be dangerous. The centre of gravity of my Special is very close to the front cross member and the car can easily be “rocked” when supported here. Cheers Howard RE: car support - David Stepney - 03-12-2021 The handbook recommends placing a short stiff bar just behind the front axle and in front of the sump. I use a piece of angle iron. RE: car support - Colin D Smith - 04-12-2021 Been out this morning and I've sorted it. Time to take it apart. ![]() |
