Sunroof clamp rail - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Sunroof clamp rail (/showthread.php?tid=6808) Pages:
1
2
Sunroof clamp rail - Tiger - 03-11-2021 Hello people Could anyone help with the dimensions of a sunroof rail for my Ruby. Also which metal would be best suited to make one myself ? For some reason I was looking for aluminium ? Regards to all Tim Just to clarify it’s the clamping rail I need RE: Sunroof clamp rail - Derek Sheldon - 03-11-2021 I think , I think that it was chromium plated brass. If memory serves me it was cast but I’m sure that one could be made of brass angle . 3/4”. Hope this helps RE: Sunroof clamp rail - Steve kay - 03-11-2021 Tim, when the sun comes up and the frost has thawed I will happily go out and measure and photograph Ruby sunroof details. Exactly which bit do you want to know about? RE: Sunroof clamp rail - Derek Sheldon - 03-11-2021 Actually it may have Mazak or as the yanks call I Kazam RE: Sunroof clamp rail - Martin Prior - 03-11-2021 The originals were chrome-plated cast brass. Austin Reproduction Parts make an equivalent in stainless steel, although it's not an exact replica. RE: Sunroof clamp rail - Peter Sweeney - 03-11-2021 My Big 7 has a Mazak clamping rail RE: Sunroof clamp rail - Nigel Ricardo - 03-11-2021 Willie Mckenzie makes them. RE: Sunroof clamp rail - Tony Press - 03-11-2021 (03-11-2021, 08:34 AM)Derek Sheldon Wrote: Actually it may have Mazak or as the yanks call I Kazam Or Zamac RE: Sunroof clamp rail - Parazine - 04-11-2021 (03-11-2021, 09:12 AM)Martin Prior Wrote: The originals were chrome-plated cast brass. Austin Reproduction Parts make an equivalent in stainless steel, although it's not an exact replica. Early ones may have been brass, all the later RP saloons, ARQ, ARR Rubies and the CRW Big Seven that I have owned have has cast Mazak rails. They break with monotonous regularity. ![]() RE: Sunroof clamp rail - Ivor Hawkins - 04-11-2021 My RP has a Mazak rail. |
