Starting handle - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Starting handle (/showthread.php?tid=6798) |
Starting handle - Ron Hayhurst - 30-10-2021 Looking through my A7 spares I find I have a couple of starting handles I need to sell-on/give away or whatever. They have the profile of those found on a 1931 Saloon as seen on parts list 670D with the part number BD114. This is the type with no extended sleeve next to the spring. However, the hole for the shaft has a diameter of 7/8th of and inch. I very much doubt if this is for an A7 so would like any comments on which engine it is best suited - and/or anyone who wants one!! Ron ![]() RE: Starting handle - AustinWood - 30-10-2021 That's for an early coil engine. Austin Seven. RE: Starting handle - Ron Hayhurst - 30-10-2021 OK. Many thanks Austin. Two starting handles are now up for sale! Ron |
