Steering column - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Steering column (/showthread.php?tid=6692) |
Steering column - rwells@talktalk.net - 30-09-2021 Do steering columns vary in length ? Referring to my previous posts, I am trying get together all the bits I need to control the magneto and throttle from the steering wheel. I thought I was well on the way however, when fitting the control lever tubes - I bought from Beaulieu - they seem too long. It looks to be about 1 1/2" to long. Any suggestions would be appreciated. RE: Steering column - Howard Wright - 30-09-2021 Hi Again Yes columns do vary in length. I leave it to more knowledgeable to record which model and year had which length column. I just cut the tubes I had to length. Make sure you have enough room to fit the lower levers. Cheers Howard RE: Steering column - Mike Costigan - 30-09-2021 It sounds like you have a short steering column (pre late-1928) for the deep-dished steering wheel, and have got control tubes for the late-1928-34 column). RE: Steering column - rwells@talktalk.net - 30-09-2021 Many thanks Howard and Mike, a great help. I now need to decide what end to cut. Do I take a chance and try to shorten the bottom ends and hope not to damage the inner tube while cutting the outer or remove the levers and cut the top ends??? Doh....please ignore my last post. Sitting watching the hairy bikers it dawned on me the two tubes are not fixed together but separate so easily shortened. |
