Ardingly impromptu - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Ardingly impromptu (/showthread.php?tid=6516) |
Ardingly impromptu - Henry Harris - 16-08-2021 Austins this evening amongst the AECs and Diamond Ts...... RE: Ardingly impromptu - Stuart Giles - 16-08-2021 Nice photos -is the blue truck a K6? RE: Ardingly impromptu - Bob Culver - 17-08-2021 Why os OY so much wider than PJ? With sloping screen and less cross sectio it is surpriing Rubys do not seem to be any faster than previous. RE: Ardingly impromptu - Henry Harris - 17-08-2021 The distortion is caused by the iPhone camera lens. RE: Ardingly impromptu - Dave Prior - 17-08-2021 Certainly in the case of MK2 Rubies the construction of the framing is quite a bit heftier than earlier models, Bob. The doors alone are a lot heavier. Sticking to that theme, MK1s are odd because Austin introduced a lot of steel pressings to parts like the doors (which they later abandoned). This makes the doors seem less substantial than other models but they are again a lot heavier than an earlier door would be. RE: Ardingly impromptu - Bob Culver - 17-08-2021 Thanks Dave RP doors with curious armour plate in the bottom are not exactly light! Compared also with my 1960s Hillman I find modern tinfoil doors with thin glass incredibly light RE: Ardingly impromptu - Ruairidh Dunford - 17-08-2021 Bumperless Rubies look great, particularly from the front. |
