Diff banjo strange welding - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Diff banjo strange welding (/showthread.php?tid=6492) |
Diff banjo strange welding - Howard Wright - 11-08-2021 Hi All I’ve started to clean up a 1931/2 diff banjo as I hope to pick up a suitable torque tube on Sunday. I’ve found this welding. The only reason I can think of for doing this is that the casting was porous in this area. Anyone else seen this? Cheers Howard RE: Diff banjo strange welding - Chris KC - 11-08-2021 Definitely seen signs of welding in that area before - why, I don't know. RE: Diff banjo strange welding - Dave Mann - 11-08-2021 I've seen that on a few RN diff cases. RE: Diff banjo strange welding - Bob Culver - 11-08-2021 Am not familiar with those cases. Could a carbon arc have been used to heat for bearing entry? RE: Diff banjo strange welding - Howard Wright - 12-08-2021 Hi All Thanks for the comments which show that my banjo isn’t the oddity I thought it was. Bob..on this axle the bearing is fixed in the torque tube which needs to be a sliding fit in the banjo to allow for adjustment in the mesh of the CW&P. Cheers Howard |
