Three Speed Gate Change Gearboxes - Printable Version
+--- Thread: Three Speed Gate Change Gearboxes (/showthread.php?tid=6471)
Three Speed Gate Change Gearboxes - jr2766 - 05-08-2021
I am in the process of rebuilding one of these gearboxes and my first problem is dismantling.
In various publications there is conflicting information concerning the removal of the layshaft and I would appreciate the wisdom of this amazing forum.
If I attempt to press the shaft rearwards first gear makes very heavy contact with the protuberance in the gearbox which supports the reverse idler shaft and I though it better to seek advice before I do any damage.
Jim Runciman
Perth, Australia
RE: Three Speed Gate Change Gearboxes - Howard Wright - 05-08-2021
Hi Jim
I don’t quite understand your problem.  The gears on the layshaft are all free to slide and the shaft should come out leaving the gears in the case.  I think your second gear might be stuck on the key?
RE: Three Speed Gate Change Gearboxes - Charles P - 05-08-2021
(05-08-2021, 07:44 AM)Howard Wright Wrote: Hi Jim
Agreed.
Make sure there's not a wear lip on the layshaft preventing something moving.
c
RE: Three Speed Gate Change Gearboxes - Rick F - 05-08-2021
If I recall correctly, there are two diffferent designs of three-speed boxes. I think there was a change in the method the selector fork rods are fitted in 1929-30. Might this be causing the problem?
Hi Rick
I believe the change was in the orientation of the gears.  Instead of reverse and first on the right it changed to being on the left. This coincided with the change from a gate to a simple ball.  The only internal differences are the selectors and the selector rods. Once these are out of the case the rest is identical.
RE: Three Speed Gate Change Gearboxes - Ian Williams - 05-08-2021
When the layshaft keys break, which is common, it set's up burs on the shaft which can be had to drive out of the case and through the cluster. Warming the cluster helps but you will almost certainly need a new layshaft once you have it out.
