Wiper motor on 12 v? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Wiper motor on 12 v? (/showthread.php?tid=6469) Pages:
1
2
Wiper motor on 12 v? - bobthompson - 04-08-2021 I want to run a 6 v Lucas DW3 wiper motor on a 12v negative earth car. Can anybody advise what type of stepdown gizmo I need to achieve this? RE: Wiper motor on 12 v? - Tony Griffiths - 04-08-2021 There are many compact "made-in-China-buy-at-your-own-risk" units on eBay: https://www.ebay.co.uk/itm/333863355574?hash=item4dbbce84b6:g:DOMAAOSwaIRZss1X I have a 6-volt to 12-volt unit to run the indiactors. I keep a spare in the glove box..... RE: Wiper motor on 12 v? - bobthompson - 04-08-2021 That one states 3 Amps at 6 volts. Do you know how many Amps a DW3 is rated at anybody? RE: Wiper motor on 12 v? - Bill Dixon - 04-08-2021 I would look out for a 12volt motor,then sell the 6volt unit. There are more 12v units about than 6v ones. These cheap units from China can be of poor quality. RE: Wiper motor on 12 v? - andrew34ruby - 04-08-2021 My 6 volt wiper motor runs fine on 12 volt, but it does get a bit hot. I have purchased, but not yet fitted, a resistor to go in series with the wiper motor, 25 watt 2.2 ohms. https://www.ebay.co.uk/itm/122180980450 RE: Wiper motor on 12 v? - Dave Wortley - 04-08-2021 My 6v "pull and spin" motor has run on 12v since 2003 without any problem. But it doesn't always rain when I go out in the car. RE: Wiper motor on 12 v? - Tony Griffiths - 04-08-2021 David, on 12 volts, does it wack around faster than on 6? I connected ours to the fuse box and it worked OK, but direct to the battery and it was a good deal better So, that's where it is, on its own fused circuit. Another member of the Sheffield group has his arranged in the same way. RE: Wiper motor on 12 v? - Dave Wortley - 05-08-2021 Hi Tony, I haven't tried the Ruby type motor on 12v but suspect it would not be as robust as the "pull and spin" type. Perhaps it would be better with a resistor in the circuit. Someone on here will be able to give a resistor value. Cheers, Dave. RE: Wiper motor on 12 v? - Bob Culver - 05-08-2021 For a heavy current device resistors are not ideal. To lose 6v at 3 amps is 18 watts; equivant one original headlamp! I trust everyone at least owns one of the very cheapest analogue meters suitable for old car use (esp if not adjusting any voltage regulators) To lose 6v at 3 amps is just 2 ohms, but the loss peaks with current so tends to drop volts at the part of the sweep where most needed, accentuating the speed variation. 18w or even 10 gets hot.. RE: Wiper motor on 12 v? - Tony Griffiths - 05-08-2021 (05-08-2021, 08:30 AM)Dave Wortley Wrote: Hi Tony, I haven't tried the Ruby type motor on 12v but suspect it would not be as robust as the "pull and spin" type. Perhaps it would be better with a resistor in the circuit. Someone on here will be able to give a resistor value.Our Ruby has a pull and spin type - it was on the car in 1970 - and I believe it to be original; am I correct? BTW, the later wiper that's fittedon the '29 Chummy works very well indeed. |
