Chummy clutch pedal lever slippage - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Chummy clutch pedal lever slippage (/showthread.php?tid=6465) |
Chummy clutch pedal lever slippage - Nick Salmon - 03-08-2021 Advice please. I've found that on the 1927 Chummy the clutch pedal lever is rotating on the shaft. I have tried tightening the pinch bolt ( I assume it is a pinch bolt) but it feels as if the thread has gone. It is impossible to remove the bolt as it will foul on the chassis so I presume the answer is to undo engine mounting bolts etc and raise the engine/gearbox and inch or more so the bolt can come out. Assuming the thread has gone, shall I replace the bolt with a nut and bolt arrangement? RE: Chummy clutch pedal lever slippage - Nick Salmon - 03-08-2021 Have been kindly told it should have a cotter pin. Looks as if I am dealing with a P/O mod/bodge... RE: Chummy clutch pedal lever slippage - Parazine - 04-08-2021 Correct. This area needs to be checked before gearbox installation as it is almost impossible to work on with the engine/gearbox in the car. You might be able to lift the engine and get access but it would be easier to take the engine out. I can do it in about an hour on my Chummy; getting it back in takes a bit longer. Gearbox is another half hour to remove once the engine is out. The clutch is completely non-adjustable as the pedal arm is locked to the shaft by the cotter on 3 speed models, hence the 3 operating levers height needs to be checked before installation to ensure a working clutch as this is the only variable in the mechanism. |
