Box saloon wing stays - Printable Version
+--- Thread: Box saloon wing stays (/showthread.php?tid=6348)
Pages: 1 2
Box saloon wing stays - Ivor Hawkins - 05-07-2021
I’m getting very close to finishing the old RP box saloon, but somewhere in the move too and from the Isle of Wight, I’ve lost the front wing stays.
I imagine they are pretty simple flat steel, can anyone fire up a photograph, so I can make a pair?
Thank you in anticipation!
RE: Box saloon wing stays - Andy Bennett - 10-07-2021
Is this what you mean?
In which case they are 18mm wide by 5mm thick. They have a twist to one end to match the wing.
hope this helps.
.jpg   wing stay 1.jpg (Size: 105.49 KB / Downloads: 299)
.jpg   wing stay 2.jpg (Size: 144.23 KB / Downloads: 300)
RE: Box saloon wing stays - Reckless Rat - 10-07-2021
Interesting. The pressed steel braces for the headlamps and the parallel braces are missing on my car.
RE: Box saloon wing stays - David Stepney - 10-07-2021
(10-07-2021, 08:22 PM)Reckless Rat Wrote: Interesting. The pressed steel braces for the headlamps and the parallel braces are missing on my car.
I think your cars should have them, Bruce. My car has both.
RE: Box saloon wing stays - Peter Johnson - 10-07-2021
I have a pair of these somewhere at home. I was going to list them on eBay but never got the chance. Where abouts are you based?
RE: Box saloon wing stays - Ivor Hawkins - 11-07-2021
Ah, thanks for posting the pictures Andy, I have the short braces, but I’m missing the longer wing stays, heaven knows where they went!
Peter, if you still have them, please pm me with a price, I’d welcome not having floppy wings, I’m based ion the Oxfordshire Northamptonshire border, near Brackley, but happy to travel!
RE: Box saloon wing stays - Andy Bennett - 11-07-2021
No problem. I had assumed it was the shorter bits that were missing
RE: Box saloon wing stays - Dave Mann - 11-07-2021
    Here they are fitted.
Thanks Dave absolutely brilliant, I now know what I’m looking for!
RE: Box saloon wing stays - Dave Mann - 12-07-2021
    Here's the outer end Ivor which has a spacer behind it.
