Fox House Inn - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Fox House Inn (/showthread.php?tid=6205) |
Fox House Inn - Tony Griffiths - 05-06-2021 Fox House Inn - Sheffield RE: Fox House Inn - Tony Betts - 05-06-2021 tony, thats fooling nobody. the house is clearly a fake. ![]() RE: Fox House Inn - Eddamoo - 05-06-2021 Been there many a time! Just a few miles up t'hill from me in Dore. Dont wish to find out how the Austin will fare on the hill adjacent to it however. Both up and down! RE: Fox House Inn - Reckless Rat - 05-06-2021 If your RP is in good order, it will tackle any hill you care to point it at. RE: Fox House Inn - Mike Costigan - 06-06-2021 The climbs up to Fox House aren't that severe; I would have thought you should be able to climb up from Dore in third gear, although you might need second on the corners coming from Hathersage. |
