SU Carburettor Needle Size - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: SU Carburettor Needle Size (/showthread.php?tid=6145) |
SU Carburettor Needle Size - Paul Lawrence - 21-05-2021 I am asking this question about SU carburettor needles on behalf of someone who doesn't have access to the internet. They have a Speedex which has twin 1 1/8 carburettors with no springs, larger inlet valves and a Fast Road High Lift Camshaft. Is anyone running a similar set up and if so what carburettor needle have you found works best for you? Thanks, Paul RE: SU Carburettor Needle Size - Terrytuned - 21-05-2021 The engine we ran with a similar spec a few yrs ago used MOW needles. RE: SU Carburettor Needle Size - Rogerfrench - 22-05-2021 I used BD needles in a similar engine but 1" carbs. RE: SU Carburettor Needle Size - Hugh Barnes - 22-05-2021 Perhaps an ideal opportunity to remind people again of the wonderful resource that is MintyLamb where one can compare different needles 'graphically' when looking for different dimensions in needles to give variation of performance... http://www.mintylamb.co.uk/suneedle/ RE: SU Carburettor Needle Size - Paul Lawrence - 22-05-2021 Thank you all for your suggestions, Paul RE: SU Carburettor Needle Size - Bob Culver - 23-05-2021 When using needle charts remember small carbs only usean inch or so of needle in normal running. The early 1 and 1 1/8 carbs seem to have the same lift range. |
