Squeaky damper - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Squeaky damper (/showthread.php?tid=6097) |
Squeaky damper - Duncan Grimmond - 10-05-2021 With twin friction front dampers I have a squeak on the nearside one. They are both at approximate even tension but the squeak is definitely coming from the LHS. I can feel it if I bounce that side. I’m tempted to put some oil on but that would be defeating the object of a friction device? RE: Squeaky damper - Malcolm Parker - 11-05-2021 As nobody has shown any interest in your squeaky damper, Duncan, I would suggest that you give the friction discs a very light smear of grease. It seems to defy logic but in my experience they are better that way, especially if they get wet. I am surprised you can hear a squeak over the beat of the lusty V-twin! RE: Squeaky damper - Ruairidh Dunford - 11-05-2021 I have done similar to Malcolm when experiencing a squeak, without any issues further along the line. Many advocate some lubrication on the damper discs from outset and I recall that they may of originally been made from material that exuded such, naturally... RE: Squeaky damper - Duncan Grimmond - 11-05-2021 Thanks chaps! Someone did suggest soaking them in oil but I thought he was pulling my leg! The lusty V-twin is quieter than the squeak...at low speeds anyway. RE: Squeaky damper - David Stepney - 11-05-2021 I seem to recall that, originally, the shock absorber discs were made of oiled beechwood. |
